Wiring An American Shuffleboard Scorekeeper
JPierson
Donor 2024
I picked up this American board and scorekeeper awhile back. The score mechanism works well, but the coin-op was vandalized when the business I bought it from was shuttered. I have a hunch the missing coin section (bottom center of the first photo) image3(2).jpeg
may need to be brought in to the mix, but I'm out of my depth interpreting the schematic and turning that in to knowing where to connect things up. I have another 10-pin to junction wire section that can be adapted, if needed. image1(5).jpeg
My plan is to connect up the score buttons at the junction in the photo, image2(4).jpeg
and then to use one of the two doorbell buttons to act as the coin insert, and then use the other as the game reset.image0(5).jpeg
I have tried a few arrangements of the wires, and I'm not getting it right by trying to eyeball the wire gauge and color. I believe the junction is in its original configuration. Hoping someone here can help answer the following questions:
- Which junction connectors are the blue and red score buttons?
- Which junction connectors are the coin-insert counters?
- Is there a pair in the junction connectors that would function as the game reset?
Thanks so much (and apologies for what is probably the incorrect nomenclature)
JP
I picked up this American board and scorekeeper awhile back. The score mechanism works well, but the coin-op was vandalized when the business I bought it from was shuttered. I have a hunch the missing coin section (bottom center of the first photo) View attachment 715761
may need to be brought in to the mix, but I'm out of my depth interpreting the schematic and turning that in to knowing where to connect things up. I have another 10-pin to junction wire section that can be adapted, if needed. View attachment 715763
My plan is to connect up the score buttons at the junction in the photo, View attachment 715762
and then to use one of the two doorbell buttons to act as the coin insert, and then use the other as the game reset.View attachment 715764
JP
There typically is a common between the red and the blue. Trace which wire is common with a multimeter. Also if you do a search on this site for American Shuffleboard Schematics, I've seen the EM's posted in the past. -Branden
Thanks so much Grubbyfsu1000 (Branden)!This helps a ton.
