Phetishboy
So, if my power cord runs directly into a line filter, can I then run the hot wire thru a 3 amp fuse, then up to the on/off switch, then to the switcher? Also, can I use the switcher's AC terminals like a dist block, or should I use a block instead? Also, you only have to run the hot wire thru the toggle switch, yes? Neutral does not need to be switched?
