a_wookie
I have a issue with my solar fire, when you start up a second player the start button also presses a tilt switch.(not sure witch one)
also when you start a single player game it also gives you a random score between 2,000 and 8,000 depending on how long you press the start button.(if you tap the start button quickly you get no points awarded)
I have already isolated the slam and normal tilt from the system but still this closure persists.
After studying and looking over the schematics package i think that the problem is with one of my N4706 IC's in my column drive. the N4706 is a hex buffer. and the ones i am questioning are IC17 and IC18 on the schematics.
any thoughts from you guys before i just shotgun both the N4706's in the drive??
your thoughts are greatly appreciated
thanks in advance
thanks in advance
