dieseldogpi
I have to fix some battery corrosion on my Black Knight I just picked up. A couple of items on the driver driver board need to be replaced and I'm trying to find out the values of the components. Pinwiki has the following drawing:
http://www.pinwiki.com/wiki/images/3/30/04-driverboard-sys3-6.pdf
But that is only system 3-6, how much changed on the driver board from system 6 to system 7? The section I am concerned with is the special solenoid section in the top left of the diagram. Thanks guys.
Also, the flipper control relay, I need to get it off the board to see if any corrosion got under it, is this the type of component tat if you desolder it it should be replaced? Its in working order.
