THE COUNT
I recently picked up my first pin, Blackout, from a fellow KLOVer. I purchased it with this issue and I need some help.
The solenoid fuse, F2, blows when powering up the game.... sometimes. It is very random and it can go for a couple of days with alot of powering on and off before it blows the fuse again. I originally thought I had it fixed, it had a 2.5amp fast blow fuse installed in F2. I replaced it with a slow blow like it should have and it took another day to blow it.
I have reseated all connectors on the boards and the ones going from the backbox into the bottom.
I have ohmed all solenoids, they read 4 4.2 ohms.
I have visually checked for any burnt wires, bare wires and any other suspicious looking wires.
Again, this only happens when I power the maching on, not while playing. Also, it may not make a difference, but when the fuse blows the master display lcd and the lcd to the right of it, are dim and kinda flickering. But if you turn the game off and power it back on this goes away.
Where should I start? And remember I don't have a Blackout manual, I'm using a Gorgar since it's the closest I can find to a Blackout manual.
