Williams System 4 MPU Repair
kencinder
Alliston, Ontario, Canada
Anyone interested in taking a crack at an MPU for me?
I've been aiming to do it myself, but I just can't find the time and I don't know when I will have the time. It's taken me long enough to poke at this enough to finally have it all clean and back together, ready to go save for this.
I'd rather let someone who is capable and has the time do it, as I just want to play this thing at this point and stop screwing with it.
No hacks done to the board from what I can see
New 40 pin connectors installed
Known problems?
Boots up, LEDs go off and come back on. Sometimes they stay out for several seconds, sometimes not and it's off and right back on.
Blanking signal goes high, goes low, goes high, goes low...reset circuit problem?
Displays throw up random numbers on startup that change, not sure if this is the displays or indicative of an MPU issue. Sure gives me the impression of again a reset issue continuously resetting.
Blow solenoid fuse from a random solenoid on startup, I'm guessing from the blanking weirdness, I've disconnected every solenoid and the transistors on driver board all check out fine.
The above first 3 are true even with the driver board unplugged.
Obviously I'm willing to pay for your services
