R3LL1K
Rebuilt the power supply by replacing every component on PS board with the exception of some transistors and diodes which tested working. All voltages are okay except for +5V.
Checked AC voltage at 3J1 pin 10 and voltage is at 10.2V when it should be at 12V. So am I to assume that this is the root of my low 5V voltage issues and that the transformer needs to be replaced?
Just in case anyone needs to know my +5V DC at 3J5 pin 6 and 3J6 pins 7-9 reads anywhere from 2 VDC-3.2 VDC.
