Williams Sys 6 MPU button
discuspro69
Austin, Texas
Looking for two of these:
Looked for them in Marco Specialties but couldn't find them. Not sure if Mouser has them either. They don't have to look identical to this one but they will have to fit like this one.
thats just a reset button
you could use a wire as a jumper
i have 2 i can take off a pac board if you want
you can have them for free
PM me your address
look at the corrosion on the solder pads on the far side of the switch
you sure thats what you need ?
I mentioned in his WTB post that I could get him some from parts boards we have at work. Since I'm local to him, that would probably be the easiest thing - unless he wants brand new ones...
Email and ask Ed if he really is out of them, sometimes his site lists things as out of stock that are actually in stock.
Yep.... I have these. Just haven't had enough time to update the website.
Ed
I guess which ever ones I can get quicker, be it used(working) or new, would be the best. I also want to replace the 8 position rocker DIPs on the MPU board. This board had some corrosion and these switches took some damage. Mod if you can get two working momentary switches and maybe a 8 position rocker DIP or two, I'll come get them from you in a couple days if you can get them that quick. BTW I also need a good LM323K T03 Regulator. Got one of those in your shop? Mod, if that will be too much trouble I will go to GPE, for the things they stock.
Sorry for the late replies, I just got back from seeing Inception. It was bad Arssssse!
I have some LM340K regulators, not sure about LM323K.
I can probably have those other things tomorrow night. I'll PM you when I do...
