nerdygrrl
Williams Swinger Em Help-stuck score relays-chimes-advance wheel
I picked up a Williams Swinger a while back and just started digging into it.
If I credit the machine I can get everything to fire. However the advance wheel stays engaged it will occasionally turn off if I hit the side targets, but will re-engage if I hit the center target.
Right now once a target is engaged the 10, 100, and 1000 point relays in the head will lock in the engaged position as well as the associated chimes. The machine will not keep score as a result. I cannot get the switch to "bounce back".
I am guessing the advance wheel, stuck relays/chimes are all related. Any ideas? This is my first EM. I have gotten it from doing nothing to this point, but am now stuck.
