I have a new Stargate that is having an issue.
At power up the game boots and does a system check and gives the message all systems go and the segmented led reads 0. I have normal start up sounds.
However the game doesn't start and gives the message "high score table reset adjustment failure." In other posts this was mentioned in the context of the battery upgrade and how the high scores are stored. However this PCB has a lithium battery mod and I replaced the battery while troubleshooting.
The following may be related, the game seems to use 12v power from the linear power supply
But 5v from a switcher. Williams factory design uses ac voltage for the coin door and this looks hacked to hell because it's using doc voltage from the switcher now. I could use some verification that the test switch is wired correctly to the interface (?) board. I have a feeling that is causing another issue that apart from getting stuck at the table I can't manually reset to game over mode to fix it.
Any suggestions-- I can't advance into any menu auto or manual I can only reset and get the same error.
Thanks everybody!
Thanks everybody!
