Williams Make Trax power supply
Arthur Dent
Donor 9 years: 2015-2022, 2025
St Louis Area, Illinois
Is the power supply for the cocktail identical to the upright? I just bought a Make Trax cocktail and every fuse on the PS was blown. I can find the manual for the upright but not the cocktail. What made me question if they are different is that some of the fuses that were used do not match what the manual lists. That in itself is not surprising to me but then I found a small envelope in the game with another set of good fuses, but they are identical to the blown set and so still do not match the manual. That made me wonder if something might be different between the two.
Well, I have a manual for the Make Trax table version on the way but I am pretty sure this just uses the standard Willams PS...same one that is in my Defender cab (although it currently powers Moon Patrol). I rebuilt that PS a couple of years ago so I should have extra fuses lying around but if you saw my basement, you would understand why it is probably going to be easier to just by some more. ;-) I may just order a few of the Bob Roberts kits and be done with it. If I remember correctly, at least one of the fuses I was unable to source locally and ordered from Mouser or Digikey anyway.
