Williams Joust - Sound is Intermittent, any thoughts?
72gto
Donor 6 years: 2017, 2021-2025
Ohio
Taking a breather from another project that's beating me at the moment and for which I am awaiting parts. I could use some solid points on the board men!
I have a Joust that is playing fine. Everything is operating normally in game play except sound. The machines here are usually powered off entirely for the majority of the week and then powered on for weekends, company, etc. I've noticed that it stops producing sounds after it's been on for an hour or so. The sound works fine everytime when its initially powered up.
I concluded it was bad solder on the input header pins resulting from heat expansion/contraction and reflowed only those. (I'm still learning this stuff so I didn't want to blindly go to town on it).
Anyone have any troubleshooting tips or anyplace I should reflow?
It sounds like a heat issue... But have you checked the caps on the soundboard? I had one short open and it just took the sound with it... But it was flaky at first... Then nothing
Hit the test button on the sound board the sound goes out.
If it comes back, you've got a logic problem on the sound board. If not, it's a problem with the amp.
