My coin door, bumpers, sling shots and possibly the radar detector lights are not working any idea where to look all the other lights appear to be working. I checked all the fuses I could find they were all good.
The lights work off a matrix method. A transistor going out on the driver board would result in all lights going out in either the X or Y of the switch matrix. Look in your manual or download one, and see if all the lights that are out are in the same column or row of the switch matrix. If so, and there is no wire disconnected, you have a transistor(s) out on the driver board.
Not sure what you are referencing by radar detector lights but all the others should be GI lights. So I would start with checking fuses but that is probably not it since some of the GI is working. It most likely is one of the GI wires or the GI connector on the power board. The connectors on the GI can become bad so you might have a wire loose for one string. I think that is the 3J8 and 3J4 connectors on the power supply board but would have to chase the wires for sure.
Marc Davis
