Slim
When I first bought this pin the receiver for the opto was pretty dirty and in the test menu switch section would always register "closed". I confirmed that the sender was at least emitting and then just cleaned the receiver with a q-tip and windex followed by drying it with a different q-tip. This fixed the problem in the test menu where it now would show "open" when I blocked the path.
The problem I am now having is when running the game I instantly get a ton of false positive rudy hits. They come in maybe 3 shot bursts (ow, ow, ow!) but just continually happens for the duration of the game even when you have not launched the ball. Back in the test menu I find that if I let it sit it will remain "closed" forever but if I start hitting the left and right flippers rapidly it will occasionally blip to "open" for a split second and then back to "closed". Does anyone have any advice what I can test or what may be causing this issue? Many thanks in advance!
