For sale, Williams Flash pinball.
Asking$1600 $1500 cash or pp
Pickup unless you make all arrangements and all I have to do is give it to the carrier.
Game works 100%. Cleaned, waxed, LEDed, adjusted... This game is in really good shape for its age. The playfield is in really good shape. Little to no wear, except above the left flipper and at the number inserts. There is a worn spot where the previous owner put Bally flipper bats that didn't fit properly. The displays have been replace w/ Wolfpac Tech LEDs. Original displays had bad UDN7180A chips. This machine has the later WMS sys6 boards. Fuse mod has been done. No battery corrosion, NVRam installed. New sockets and 40 pin connector.
The bad: Original back glass does have some scratches, but a previous owner spray painted the back white. This actually prevented further damage. Can hardly tell from front, even when game is on. One rear leg is different, gray instead of chrome. Right side of cabinet does have some scratches and set in dirt.
The game is currently in my basement, but will have it available in my garage for easy pickup.
Asking
