William's Flash GI lights not lighting anymore...
Bullwinkle
Rochester, New Hampshire
OK, I was working on my Flash machine, playfield up and trying to fix the last GI lamp that was dim. I moved it slightly and all of the GI lights went out. I checked the lamp I was working on and I haven't caused a short (at least not a permanent one). If it did short and it doesn't seem to be the lamp I was working on , is there a fuse it may have blown or have I opened up pandora's box? Any suggestions on what I should check?
Thanks,
-Tom
The socket itself could be defective and shorting. Check it with a DMM.
There should be a fuse for the GI circuit as well. You probably blew it.
There's a single 20 amp fuse for the general illumination in the backbox.
Williams issued a service bulletin to convert the single 20 amp fuse to 4 seperate 5 amp slo-blo fuses for improved operation/reliability. This gives 4 seperate general illumination circuits:
2 for the backbox lights
2 for the playfield and the coin door lamps
This helps narrow down bad lamps/shorted sockets without killing the entire general illumination circuit. Most of the machine could still remain lit.
That's a great idea! I'm glad I didn't see this last night, I would have stayed up until 3am converting it over! :) (not to mention I did not have a 20am fuse, but had plenty 5amp slo-blo fuses and a 4-fuse fuse holder available.
I did see there were multiple yellow wires going into and coming out of the fuse, I will assume (although I'll verify when I get home) that there must be 4, hence the 4 fuse conversion.
Ken, as always..thanks for the tip!
-Tom
The service bulletin was issued around 1980 or 1981 IIRC and was in a Williams pinball binder. I wish I still had it because I would scan it. I don't think it ever got posted anywhere.
