Williams Firepower pinball led problem!! Please help
noname707
Santa rosa, California
The machine worked fine. We moved it to the garage and now none of the led scoring lights work at all, everything else still works fine. I checked all the fuses and connections what else should I do??
Sounds like a connector issue and maybe some cold solder joints on them, pics of that area under the playfield would help, moving old pins can cause cracked solder joints, bad grounds to a socket, wires to become loose or broken from there joint, bad connectors or header pins to show you the issue, my guess would start here
