KCHVAC GUY
Restoring this game and after re-installing all the play field parts I have a couple of issues.
A few lights wont come on off hand here is what I recall.."Shoot Again", Number 4, and the 3 rd light on the Extra Ball targets. Diodes are good, cleaned all lamps, and brand new bulbs.
Two targets are not working located straight front right center. I noticed a previous replacement was made on a target and no diode is present. I did not test much before I stripped the game since it was in storage for years wanted to clean it before I ran too many test. So Im not sure if they worked before. I take it the diodes are used to prevent reverse voltage but wasn't sure without diode will the switch work? The blades are making good contact with each other.
The sound for game play works good but the words are gargled, I know it did work good before I stripped the game so I screwed something up. Connections seemed solid cleaned semi corroded potentiometer tabs with rubbing alcohol still no luck.
Any hints would be helpful to help speed up my troubleshooting Im used to EM games so this is a little different then I'm used too.
