Williams Fire wire harness question. Tech
TulsaTime
Tulsa, Oklahoma
Hello. I just inherited a Williams Fire! pinball machine. It has a system 11A board set. I have one 2 pin molex connector at the back of the machine which I can not find where it connects to the large wire harness connected to the play field.
I can tell you that the wires going into the 2 pin molex connector appear to be:
1 Gray (with candy cane yellow stripe)
1 Black (with candy cane yellow stripe)
It doesn't help that I can't read Williams wire coding correctly.
On the schematic, the gray wire look like it is connected to the flipper power supply. I don't know if that will help or not. Please write me if you even have a clue. I know I don't.
Thank you,
Bill
Thank you,
Bill
Do you have a manual or schematic? I think that connector is J16, on the left side of the interconnect board.
