Williams coin door inserts
denikar
Donor 4 years: 2012-2015
Canton, MI, Michigan
I picked up some new coin door inserts for my Defender and have been scratching my head for the past 15 minutes trying to figure out how to put them in. I see two nuts on the back holding the coin assembly in place, but fear if I loosen them the whole assembly will come apart. Any advice on how to do this would be appreciated.
Thanks,
Tim
Thanks,
Tim
(Assuming this is the stainless steel door...)
Remove the two screws along the top, above the coin slots, from the back of the door. The coin entry panel then hinges down from the front of the door. Then there are two screws on each coin entry bracket. Remove those and the bracket, and out come the metal entry piece and the screened plastic piece. Put it all back together with your new screened plastic pieces.
Duncan
