You don't need anything special. Any 20amp fuse will work as long as the voltage rating is higher than the voltage rating of the original fuse. You should be able to find a local store that has them.
The voltage rating only comes into play when the fuse blows. When the fuse goes open, the voltage rating is the voltage at which the fuse will safely stay open and not potentially re-energize.
