- Joined
- Apr 16, 2012
- Messages
- 25,896
- Reaction score
- 12,997
Williams Backbox Interconnect Board - need a Connector
Hi all,
I was troubleshooting a Diner that had lost general playfield illumination. I backtracked the wire through the D-12313-571 Interconnect board, all the way to connector J6. When I looked at the wiring harness connector, it was pretty crispy (so crispy, that when I tried to remove it, four of the pin housings disintegrated into dust and small "connector-ette" pieces.
I pulled the board and had to re-flow the pins for the 4 hot connectors, then reseated everything, soldered the wires to the remaining push-connectors (no plastic, no connection), then I added Heat Shrink to keep them isolated.
Now all my GI lighting is back up pretty much. However, I'd like to re-do the connector.
The board connector is a 5791-10862-09 - does anyone know where I can get the harness connector to go with this board connector?
ArcadeTech GW
Here is the troubleshooting plan, in case someone else has problems:
Diner Troubleshooting Plan
At Backbox Interconnect board:
At Jumper 2P7 / 2J7, check for 6 volts at 8 and 7, to Pin 10 and 9
If No Voltage
On the right side of F1, check for 6 volts – Black lead on Pin 1 of 2P6 / 2J6
If No Voltage
On the left side of F1, check for 6 volts – Black lead on Pin 1 of 2P6 / 2J6
If No Voltage
Check Pin 3 of 7P3 for 6 volts, - Black lead on Pin 1 of 7P3
If No Voltage – Power Off
Backtrack continuity of Yel – Wht wire to transformer
Hi all,
ArcadeTech GW
If No Voltage
If No Voltage
If No Voltage
