ManiN
Anybody have their unit fail where it won't be recognized and also when you plug it in the serial, the power LEDs no longer emit as usual until you hook up say, the 12V power supply? Before when it seemed to be working right, you would hook up the parallel port cable and the yellow LED, if I recall, would illuminate and then the system would be fully up when the 12V line was hooked up.
I merely pulled it out of storage after using it the previous day, and it wouldn't power up, at all. Checked typical things like cold solder joints etc.
I tried searching all over the net for some similar posts of others as they are used big time in car enthusiast sites etc. but no joy.
I think it's the older PCB3B
Anybody?
Anybody?
