Will this tube work with a 25 inch chassis?
wolfeel
fortuna, California
I am going to build an 60 in 1 for my little cousins and wanted to put a 25 inch monitor in it. I have a tube from a TV and want to know if anyone knows if it will work with any chassis an if so which one?
The tube is: Sharp A63ABG25X
Thanks for any help.
The tube will probably work with any 25" chassis, provided you also have the yoke that matches that 25" chassis. Pretty much all 25" TV's were 10-pin necks, and I don't know of a 25" chassis that wasn't also....
I have picked up a few 25" TV's that are ten pin but in a different arrangement than the typical arcade monitor chassis, I believe they use a CR-20 adaptor.
According to the following chart (B&K rejuvenator set-up manual) it looks like your tube uses the standard CR-23 adaptor and should work with most chassis.
http://www.bkprecision.com/support/downloads/pdfs/CRT_Setup_Chart.pdf
