linx310
Will the centipede 22 volt/-22 volt lines work with 24 volt/-24 volts?
Working on a custom project that requires me to supply power to a centipede board with out using the AR2.
The high score save chip (the ER2055 EAROM) uses the -22 DC volt line. The datasheet for that chip says it can handle -28 volts (unless I read it wrong).
If I supply the 22/-22 volt rails on the board with 24/-24 volts will it still work? For the TI 7815C and TI 7915C voltage regulators some data sheets say max input is 23 volts, others say its 35 volts.
Are there spots on the board where those voltages are used for some thing else that may cause a problem?
