will any 27" monitor with chassis swap games
bigaw
Riner, Virginia
have off road thunder need to put complete monitor in will any 27"monitor and chassis work out of another game.
No.
Most arcade games have either standard, medium, or high resolution monitors. You need to be sure to match the monitor to the game's resolution. Some games can switch resolutions via DIP switches on the board. Some do not.
Also, the mounting brackets are often different between brands. Example, Nanao will have a different mount than a Wells Gardner. If you are handy with tools, you can work around this part.
monitor swap
thanks for information.think i will just order a well gardner D9800 wanted to try to keep it orginal
