Will a 2 board set Donkey Kong fit in a Cabaret?
Tighe
Richmondville, New York
Is it wider and taller than the 4 board set that is in mine? Just wondering if I need to buy a new board if it has to be the 4 board set.
I think you can go from 4-board to 2-board (as long as there's room...there's not in an original DK cocktail), but if your machine is wired to use the edge connector only, you wouldn't be able to use the 4-board since it only uses the little rainbow connectors and has no edge connector.
