Wierd problem with my JPac and PSX
Arcade74
California
PROBLEM:
Wierd problem with my JPac and PSX/PSX2.
Contacting the maker, they said it is a grounding issue.
Player 2 controls cuts out, and its not a wiring or grounding issue.
FACTS:
I am trying to figure it out, but its been a while. Here are all the facts:
-PSX2 is modded with modchip
-The jamma power wires are cut (it can be uncut if desired), because it is not needed as the PSX2 controller is powering it.
-it happens randomly, and player2 just cutsout, not a wirign or ground issue. Checked by volt meter.
-If i unplug PSX2 cable wire to the JPac, it will reset someting, and everything is good for a while, until it happens again.
-Then I figured what happens if I swap PLayer1 and player2, it will start happening player1 side will cutout randomly(and now player 2 side plays fine). Thus it is not a wiring issue, also checked by volt meter.
HELP ME:
Could this be a faulty JPac?, green gound wire needed somewhere?, something??
Hoping someone have had this issue.
You seem to have answered your own question :
PROBLEM:
FACTS:
If the Player 1 controls work fine when plugged into the Player 1 side and the Player 1 controls work fine when plugged into the Player 2 side, you can safely assume the Player 1 controls are not the problem.
If the Player 2 controls don't work when plugged into the Player 2 side and the Player 2 controls don't work when plugged into the Player 1 side, a little Sherlock Holmes deduction reveals the the problem is the Player 2 controls.
If the problem was anything to do with your JPac then the issue would remain on the Player 2 side.
Your issue exists somewhere from the Player 2 connection cable through to the actual Player 2 controls.
Start by cleaning all the contacts (Player 2 controls plug first) and then double check the ground wiring.
Brian.
Brian.
No I did not state that...
The problem is switched to player1 side if I switch them. Any other thoughs on it?
Ummmm.... That is exactly what I said....
The Player 2 controls are what is malfunctioning. If you plug them into the Player 2 side, then Player 2 works intermittently. If you plug them into the Player 1 side, then Player 1 works intermittently.
If the problem stayed on the Player 2 side when the controls were switched then it would be a problem with your Jpac.
Brian.
Brian.
Im prob just getting confused on terms.
The problem does follow "palyer2" and when switched it happens to player1 side (Left side with palyer2 inputs). I am thinking JPAC too. How do I figure whats wrong with the Jpac? Anybody have the same issue.
Ultamrac did not offer any help other then a grounding issue. I have read others having the same issue, but not a solution yet.
