FS Parts: Wico Perfect 360
kj4860
Texas
Rating - 0%
0   0   0
I've got a rather nice selection of the elusive and exclusive Wico P360 and Perfect 360 Happ/Wico base assemblies (no shaft) im looking to sell/trade:
X5 Wico P360 pcb & bases with necessary Wico shaft accessories redrawn & newly 3D printed (wood/metal panel spacer+pivot cone combo, actuator), pcb/bases all in very good used shape -------- $140/ea. shipped in USA $115/ea. shipped in USA
X1 Wico/Happ Perfect 360 upgrade board with Wico base & base adapter. Honestly not sure what size shaft the stock white spring base on this uses. Comes with Wico P360 accessories (wood/metal panel spacer+pivot cone combo, actuator, spring base) redrawn & newly 3D printed IF NEEDED, all in very good used shape------- $125 shipped in USA $105 shipped in USA
X1 Wico/Happ Perfect 360 upgrade board with Happ housing adapter only (can be used on Happ Super housing), repaired/replaced missing quick connect; comes with accessories of either Wico (wood/metal panel spacer rings, cone, actuator, spring retainer) or Happ (actuator, spring retainer) redrawn & newly 3D printed; cleaned as best as possible but considered OK/gamer condition overall, ***BONUS*** Comes with original WICO 360 dust washer ------- 110$ shipped in USA $95 shipped in USA
All pcb tested working on a single base with a MC Cthulhu setup.
3D Printed parts:
Copied Originals:
-USA Happ Super Spring Base
-USA Happ Super Round Actuator
-USA Wico P360 Spring Base
-USA Wico P360 Actuator
Modifications:
-Happ Super Spring Base+8 Way Actuator (for using a Happ Comp shaft in Happ Super base; allows 2nd lowest e-clip ringlet to be used; tested with Perfect 360 upgrade board ONLY)
-Wico P360 Pivot Cone+Spacer (due to the diameter of the original spacer rings being nearly impossible to print, i have merely combined the pivot cone with each spacer to form four separate pieces --- pivot cone no spacer, pivot cone wood spacer, pivot cone metal spacer, pivot cone both spacers; no setup test performed with this design, only fit and function with the base)
-Wico P360 8 Way Actuator for Balltop shaft (the NOS balltop shafts typically offered on eBay are ever so slightly too short for using the original P360 actuator)
***Note #1: While i have printed/modified/redrawn all of the components dozens of times and tested each, i cannot attest to them being 100% identical to the original in the "feel" department". The current array of designs i have made works great for me, but this will vary from person to person.
***Note #2: All parts provided with assemblies will be printed in black
***Note #3: No warranty on 3D printed or Wico/Happ parts.
***Note #4: I will not provide STL or any other drawing files; willing to sell the printed parts individually/as kits once the above joysticks are out of here.
Looking to get prices listed –or– part $/part trade for NOS Wico P360 battop shafts (in color other than black), Stainless SlikStick, and/or Perfect 360 buttons (spill resistant opticals) in yellow, green, or black.
Any questions, comments, concerns, let me know. Thank you :D
Pardon my ignorance, but what were these originally used in?
They are popular for fighting games, especially the Marvel vs Capcom games.
I am possibly interested in couple of the wico bases. It's been a while since I've looked into these, can you confirm they are compatible with happ/happ-il joystick shafts/springs?
Indeed - i am a FGC player/collector thus the reason i picked these up and decided to give a bit back to the community, if possible.
Happ shafts are natively incompatible, as they are just a hair wider. However, with the kits ive drawn up, you can use the NOS Wico Balltop shafts readily available on eBay.
Happ springs are very close and appear to fit the spring base, actuate fine, etc. but aren't quite the right fit up. Perhaps the ol' stretch and heat technique can get it just right but otherwise, each base comes with a Wico spring anyway.
Lastly, i am drawing up modified Wico parts to accommodate a Happ Competition as we speak. Will they work? I dont know. They should but this will take some time for not only drawing but some testing.
Just know that even as i do this, the assemblies are going as-is with the current printed parts on eBay. If i happen to sell these bases on eBay, they are gone. I have one on hold MAX and that spot is taken.
If you want to work something out, let me know soon. Thanks
