Wico joystick leaf switches
BeagleBoy
Iowa
One of my robotron-type wico sticks has a broken leaf switch (broken tab). I can jury-rig a connection, but I'd rather replace it.
Any sources?
-Jim
Mine have a plastic or fiberglass leaf on the inside. I'm assuming I'd want to keep them matched.
-Jim
those are factory wico switches. my two in my multi williams both came with that black plastic leaf switch. they should be correct for yours as well.
The tension plastic is a separate piece ( and part # which I do not have) but they can be removed and added to a new switch.
Great! Now that you've pointed it out, I can see that the plastic piece can pop off. That makes things much simpler.
