TheMaze
Wico/Happ SUM-20C - Vertical bend for top 1/2"
I just re-capped my Happ (Wico) SUM-20C monitor as it was showing a little shimmer. The good news is that shimmer is gone. The bad news is I'm still seeing a geometry issue. This issue *was* present before re-capping - I was hopeful that the caps would fix it (alas, they did not).
See the attached picture - the top 1/2 of the monitor has a bit of bend. This doesn't seem to move at all - it seems constant. Thoughts on what the cause is? Or am I expecting too much out of a cheap monitor?
