Why??????
LUCKYMAN
Clifton Heights, Pennsylvania
Would anyone know why my BATTLEZONE power brick is missing the VOLTAGE PLUG ASSEMBLY??? Is it the way its suppose to be??
Heres a pic for what the manual shows:
heres a pic of mine:
Mine dosent have it at all, even where it shows the wires going to the transformer, i dont have any cut wires or any of that.. is this something important or should i not worry about it?? All my voltages are good in the machine.. i just dont understand
It's pretty much the same supply.
His pictures appear reversed because the photo is a shot of the underside and the PDF screenshot is from the top.
He's complaining about the circled connector near upper center that is missing in his game. It is used to strap the supply for different input voltages. They came with little plugs that would allow the game to operate at 100V, 120, 220, and 240 by connecting the AC input to different lugs on the transformer primary.
By the way- if your assembly is hardwired for one voltage and you're wanting it wired for another, can't you just clip and resolder to the desired input lugs? I can't see the photo while typing this in- does your transformer have the different inputs?
K
no different inputs..
If its something i dont have to worry about then i wont.. im not tring to change anything... I was just wondering why it was missing on my battlezone, but it shows it in the manual!!!!
PS.. my pic shows underneath, im showing it that way to show that there is no other wires going to the transformer from this thing that is missing!!!.. everything is original
