purbeast
I'll be the first to say that I don't really understand how under the hood monitors work, so I'll just get that out of the way.
But I was wondering why in the same arcade cabinet, when I put in different JAMMA boards, why do I have to adjust different monitor settings? And I am not really talking about color/contrast but more about position/size.
For instance, in my Maximum Force cabinet, I have it set so that Maximum Force is perfectly centered on screen with full screen and what not.
But when I put in my Carnevil board, the screen is shifted big time to the right. It's so big that the pots on the remote board for H.POS aren't enough to move it to the left to center it. I have to go behind the cabinet and change pots on the chassis board.
I am just wondering why this is the case. Why doesn't the "picture" get set and then anything it outputs is just displayed in the same position with same dimensions.
Main reason I am wondering about this is because I just put a switcher in my cabinet and am trying to figure out if there is any way at all that I can find a setting that will work for all games, because having to go behind the cabinet to change settings when I switch games, really is going to take a lot of the point out of the switcher. I also kind of assumed that I would set the position/dimensions for the switcher and all games through it would look the same - bad assumption on my part I guess.
I also plan on doing a capkit in the near future, and I was wondering if doing that will have any effect on how much the H.POS on the remote board would change it, so that maybe I could get it setup where I only have to adjust the pots on the remote board which I can do from the front. Ideally I'd like to NOT have to do any of that but could live with that.
