Why are people so incompetent/lazy with JAMMA wiring?
So I just got my Double Dragon today and all is well except there is an issue with the monitor picture. This was something that the seller was upfront about from the beginning. He is not the first owner and had attempted no repairs other than getting a new marquee and replacing the speaker. At first, I thought it was just the usual adjustments, needing a cap kit, etc.
Then, I took a look at the JAMMA wiring at the edge connector and there are two wires all hacked up and both were soldered directly to the board. I mean seriously, straight to the board? Then I notice one of the wires is soldered to another wire at the edge connector. When I removed these connections, the picture went fuzzy and brown.
After a few minutes of closer inspection, I narrowed the two wires down. One wire is for a player control. I'm guessing the wire broke off and they just decided to "fix" it. The other wire (speaker wire) is soldered to the video sync wire and and was then soldered to a ground connection. I don't know the reasoning behind this.
So it's just a bit of a mess that I'll have to clean up. It just makes me wonder why some guys think taking the easy road will fix their issues. I'm guessing whoever did this didn't know any better or was just plain lazy.
So every JAMMA cab I've gotten has had hacked up wiring in some form or another. Just frustrating. Either this is a common occurrence or I just have bad luck with JAMMA cabs.
Picture of hack job attached.
EDIT: So the red wire was for Player 1 Up and Down. The other wire is jumpered from a video sync wire to a ground. The picture will not show up unless it is jumpered this way. I have no idea. I really don't care. I'm going to end up replacing the entire JAMMA harness anyway because the connector and pins have corrosion.
