Nice thread, love me some Btime. I am not great at Btime, but routinely get 120k+. There are a few things you can do to increase your score. There are better players that may have additional tips or edits of these, but these have worked for me in the past.
The burger ingredients can be tricked. If you turn one way or another or go up or down a ladder it will make them do it, so you can do some shimmy moves to trick them.
The ingredients generally only go up or down one ladder in distance, so if you are trying to line them up for a big drop, keep in mind that they will not travel the further than a ladder in distance.
Always get the ice cream. It will give you points but also a pepper. Peppers are critical as you get to the harder boards.
Try to get the ingredients to group together. Sometimes you have to use a pepper or two to get them to posse up, but if you do you will get a lot more points when you drop them. The other good thing is that they will generally reappear together so you can continue to drop multiples.
There is a tendency to drop the burgers from the very top down and you get good points for this and you clear boards faster, but if you drop them from the bottom up, you will get a ton more points, both in dropping ingredients and getting ice cream/peppers.
Other than that, try to get some patterns down on the tougher boards. Sometimes you will miss a pickle or burger patty by millimeters, but the timing is everything to get to a place where you can drop em like its hot.
Man, haven't played Btime in 3+ months, but will tonight!
