FS Game: Who wants to buy my collection? **UPDATED 1st POST**
This reminds me i really need to make a spread sheet of my stuff and would be great if someone could buy 50+ games at once, although i probably want more than your asking. Definitely though, be sure to get payment in cash rather than check just in case.
**The OP has been updated**
Photos of Crazy Kong. One pic is of the side art I had printed up. I didn't put the side art on because the sides of the cab need to be sanded and re-finished IMO as they have an ABS veneer that was cut too short so there's a seam at the top. It doesn't look horrible, just not good enough for me to want to put the side art over it...
Pole Position Photos. There's some damage to the side art (the worst is pictured) and the CP and CPO could use a bit of restoration, but it doesn't look horrible. I recently cleaned and rebuilt the accelerator pedal and the game works great.
**NOTE** The shot of the screen has a bunch of lines in it for some reason. This is from the camera. It's not present when playing the game.
Assault Photos. The side art was apparently trimmed by someone to remove the section by the control panel that traditionally gets damaged. The CP has some carriage bolts that were added due to the lock down tab under the CPO being broken off. The tab could be welded back on, the drill holes filled, and the CPO replaced. But it looks fine the way it is.
Yes, the sticks are original and yes, they have slop in them. But they are fully functional and the game works great.
There's a photo showing the new t-molding, but the gray will not be used for this game. The black molding for the base does NOT have the ridges in it, but I never cared about that. It has since been installed on the base.
P.O.W. Photos. This POW was a conversion of a Track and Field. I bought the game with the intention of de-converting it.
The game will come with a Track and Field PCB that's complete but may need to be fixed. I'm not sure because I've only tried it with a Konomi to JAMMA adapter (which will also be included) so I don't know if it will work with a normal Konomi harness or not.
The game also comes with a brand new Track and Field CP (without the CPO) and a brand new marquee (will need to be trimmed to fit.) These items are in the last photo.
The cabinet does have some damage to the left side (shown in photos) that will need to be repaired. I'm pretty sure that this will need to have a whole new piece of MDF cut and fitted into the spot.
The POW game itself works perfectly.
The Centuri coin door alone makes this cabinet a find and worth way more than I have it listed for at the top of the thread.
I've got the Leland Quarterback and the Off the Wall back together and working but haven't taken photos yet. I'll take and post those photos tomorrow. I'm also planning on working on the Battlezone and Galaxian this weekend, and I hope to have Galaga back up and running tonight too.
Either way, I'll definitely post photos this weekend of the following:
Ms. Pac-Man
Quarterback
Off the Wall
Megatouch
Donkey Kong
Missile Command
Galaga
As well as anything else I happen to get working...
Photos of Leland Quarterback. The CPO is damaged (shown in last two photos) and the monitor needs to be capped to get rid of the lines on the left side of the screen and bring back a little color. But the game is solid other than that.
Off the Wall photos.
First photo shows the game working while the rest show it in its final state. It's not a full restore as the cabinet still has several blemishes, but I just wanted to get the game into a state where it could be put into someone arcade without additional work.
I scanned the thrashed bezel and did my best to fix it up. It's not perfect but I think it turned out pretty good.
This cabinet could be converted to a Phoenix or similar.
Missile Command photos.
This game has the board out of it and being repaired, but once I get that back and install the new plexi (clear, not smoked) I just had cut, this will be an excellent example of a cabaret MC.
The CPO is new, the bezel was reproduced by me off of the original one that was thrashed. The bearings on the trackball have been replaced and the cones on the fire button are new. The wood grain siding is original and in great shape. The coin inserts are out of the game, but I'm trying to find them to reinstall.
As for the photos of Ms. Pac-Man, Megatouch, Donkey Kong, and Galaga, I have a lot more stuff to move around to get the games into good positions for good angled shots. I'll have them up asap.
That Missile command cabaret is extremely nice. A lot of these games are in nice condition.
Good seller to work with😊
