nanoryan
Think im going to start in soon on a basic Multi-Williams CP (converting an old Joust CP). What's the consensus on the best CPO? I dont like the look of the AS version.
Thanks!
Thanks!
Wow! That is a toss up!
artwork doctor has one that's cheaper but i've read very mixed things about the quality of his printing (mostly negative.)
A toss up between what??The only ones I know of are AS and Phoenix .. I like the Phoenix but want to see what other options are out there before I pop for $70 delivered.
Basically, the setup is going to be a JROK Multi-Williams PCB and a Moon Patrol PCB .. probably switched via a Multi-JAMMA kit.
Thanks!
I really like the Phoenix version, bought one and went through the CP modification using a hacked Joust panel. I have some stainless steel plates made that fit the panel if you don't want to use bondo and also have the joystick dust covers under the CPO. PM me and we can work out a cheap deal to get one to you. (I have 2 with no holes 16 gauge, 1 with holes, but 14 gauge and you will need to use a dremel to finish the holes (what I did on mine).
I'm now into the cabinet wiring phase of my JROK MW, but take a look at my CP job, it may help you decide. I really like the Phoenix CPO with the Joust Bezel, but Joust is my Grail, so I am partial to the artwork.
http://forums.arcade-museum.com/showthread.php?t=117871&page=3
