who owns blueprint and lazarian/domino man?
DPtwiz
I want to scratch build a blueprint, and trying to figure out the cabinet. There's a bunch similar.. bump n jump, journey, 6pack cabinets, blueprint, domino man, and lazarian that i can think of.
Journey/bump n jump, bezel angle is wrong. I've never seen a 6 pack cab in person, or a blueprint. I have a lazarian/domino man cabinet, they are identical, other than they cut a speaker into
the panel above the bezel for domino man, mine had lazarain art under the panel, factory converted. Here's a few pics i put together, i am 99.9% sure, same cab.. anyone own both??
edit: i know lazarian is horzontal, but i don't think that affects it.
Dimensions in the flyers are different. Blue Print is deeper (also the case when compared to the six pack cabs).
thanks! now i will look for the journey and bump n jump flyers for dimensions too.
Here's the dimensions of all 4. The top right is bump n jump. 25 5/8 is a misprint. It's 24 5/8 wide. I copied my original and built a new one, and checked my file. I think blue print is bump n jump overall, i just have to fix the bezel angle and around the monitor area. I will overlay lazarian over my bump n jump to see if anything lines up, i may be able to use elements of both to get it pretty darn close.
overlaying worked great, the fronts matched up well, i used the speaker panel, vertical panel behind it, the bezel support strips, and the front bezel crossbrace from lazarian, and the rest from bump n jump. blueprintlayout.jpg
I've got a Blue Print cab (ID'd based on measurements) here in Portland that was converted to an Arch Rivals. Let me know if you need anything and I'll see what I can whip up for measurements/pics.
when i cut one later this year, i'll make sure i have a marquee, control panel, and at least the correct bezel size (no repro's exist yet) and i should be able to mock it up and see if anything needs adjusted.
