I'm pretty sure I installed it correctly, I had installed it the the same way the previeous chip was in, but I will double check. I also posted a picture of what the screen looks like. I do hear the "beep" when powered on, but then the screen is all I get.
I checked that, its fine. I looked at the board while on and only one led was lit. The sound led is lit but the "d.drive active" led is off. What does that mean?
Show us a picture of the bootrom installed and the flash drive plugged into the board. After you hear the chime can you hear the game going into attract mode? Check the JAMMA connector as well just to make sure.
Same thing, the only difference I may have noticed was the "d.drive active" led was lit before the flash kit and bootrom installed, but I could be wrong.
