White screen - possible ps problem?
VIPER13
Michigan
Possible power supply problem?
I am having a problem with my Gallag game. It recently started locking up and had a RAM OK message upside down on the lower right corner of the screen. After a couple of more start ups it now just has a white screen. When I replaced the power supply a while back I never checked the volts and since the game was working just fine I didn't worry about it. Is it possible that I ruined the power supply, board or both by not having the correct volts? I recently checked and set the volts to 5.1 and 5.2, but neither helped. I did notice that after setting the volts if you turn the game off and on again the voltage will change slightly. Is there any way of checking to see if the power supply is still good or is there anything else I can check on the board?
