Whirlwind Spinner Not working even with new Motor
DreamTR
SMYRNA, Tennessee
New motor installed, fans seems to be "locked" in place, spinner is "on" in the test menu but nothing happens. Fan topper nothing as well. Anyone have anything specific they know I need to be checking?
I had the same thing happen. Fuses looked good so I skipped over them. could not find anything wrong till I pulled the fuse and tested it. it was blown but looked pefect.
I think the lightning flash on ball launch is on the same circut as the both fans also
theres a single plug running from the backbox, to under the playfield...make sure thats connected. its a single plug male to female ends
bet this fixes it
If the plug isn't the issue, First check F3 on the Aux power driver board (2 1/2 amps). 2nd check the connection J4 and J5 on the sound overlay solenoid board. If when driven you have voltage (25V) at pin 1 on J4 to pin 7 on J4 (Snd ovrly BD) you probably have a bad connection supplying the motor. If you don't have voltage check Q13 (TIP36C) and Q14 (TIP122). Both also on the sound overlay solenoid board.
