Whirlwind not locking ball for multi-ball
blkdog7
Massachusetts
I am pretty sure, bot not positive that when I shoot the ball up the right ramp it sends the ball to left and the ball should stay there, then you launch a new ball. Right? Mine does not do that. When I shoot it up the right ramp, it goes left then the plunger ejects the ball out of the left chute. Is there something I should do to fix this? I have yet to see multi-ball.
Thanks!
Put the game in test mode, (switch check) and place the balls in the left lock lane, one at a time. Make sure the game sees all three switches, and that they are wired correctly. It should show, lock1, lock2, lock3. Does the test report show any errors?
-Mark
THANK YOU!!! I did this and found the back switch wasn't reading the ball. I adjusted the wire and now I have multi-ball!!! WOOT!
Multi-Ball is definitely working now. Wow, it's like a whole new game now.
Now, I think there is one more minor problem..
There is a gate that swings on the top right near the multiball drop. It's supposed to close so the ball goes right and drops by the left flipper. I have yet to see that gate swing. Any ideas?
