Which PCB is best for a Neo-Geo 111-in-1 cartridge?
mudmantim
Vermontville, Michigan
Seems like I remember the bigger multi Neo cartridges only working on certain PCB's. Is it just the newer 1-slots or something else?
I have an older 1-slot and was needing some input on whether this is an option.
Also, does anybody have a list of what games are included on the 111-in-1?
Thanks.
-Tim
It's supposed to work fine on the 1 and 2 slot mobos. I believe the issue was with people that had installed unibios on their boards.
You can find the list HERE I think you should stick with the 100-1 since the 111-1 only has more hacks of games already found on the 100-1. Hacks don't justify the higher price for me.
Thanks for the link.
I just got this info from China: " The 111 in 1 cartridge is work on the Neo Geo Mother board is better used the model MV-1A, 1B and 1C 1-slot."
My PCB is a MVH?
Mine will work? or no?
Thanks.
-Tim
i have used a 100 in 1 on the mv-1f wich is a newer revision of the 1h i dont see why it wont work most of the problems people have are with the 4 and 6 slot boards or the mv-1b due to the mv1b being made for irrating maze carts and even then you ust have to replace the bios
read more on the mv1b here
http://www.hardmvs.com/html/MV-1B.htm
most of the bad things said about the 1xx in 1 carts comes from the neo geo nazis at neo geo . com that think these 1xx carts ruin the value of their original carts or since they are bootlegs they just are not good all around (kinda like the mame and multi board haters here)i have used the 100 in 1 carts without a problem in up to 4 slot boards the only board i had trouble with was a 4 slot that had a unbios in it and even then it worked but i could only have the 100 in 1 cart in use it would not switch games
