Which K7000 series Monitor is this ?
ScumBum
California
I wanna order a cap kit from Bob and noticed he has different kits for different K7000 monitors . Which one is this , it has the remote board ? Thanks ,
you said it, k7000.. a k7000 is known as a k7000 is known as a k7000.
yes there are many variants and variable identifying #'s after the 7.... example k7191
however when you see that board and it will be known as a k7000..
that one is a 19".. all 25" have the giveaway larger vertical heatsink.
Some K7000's were made with all the adjustment pots on the main board and others were made with a remote adjustment board.
I understand his question, and his confusion.
When people refer to a K7000, they're referring to this particular chassis and all its variants. With remote adjustment board and without, 25", 13", 19", etc etc.
There are other WG monitor models that start 7xxx - K7400, K7500. Even though those model numbers are in a similar format to a 7193, 7901 and the like, they're completely different. I can see how you'd get confused!
