Which joystick to use?
cmkryzer
Minnesota
I have a Super Cobra cab converted to a Time Pilot 84. The joy stick is original to the Super Cobra so it always pulls to the left. So I wanted to replace the whole CPU but can not find one. So will a Happ 8 way joystick fit in its place or will i need to redo and wiring and drill new mount holes??
I am still new to the hobbie, so not sure what can fit where /...
Thanks in advance ..!
I can't think of any reason why you'd have to replace wiring, but sometimes it's soldered to the original joystick and sometimes it uses a quick disconnect. You can easily retrofit by crimping quick-disconnect terminals (link) to avoid soldering, if supported by the new joystick.
The Happ website also has mechanical specifications for every joystick. For example the Happ Competition Joystick (link) shows:
This one shows a rectangular mounting hole pattern 76mm wide x 66mm high. It will vary depending on the joystick. Again, measure the mounting holes for what you already have and check if Happ sells something with the correct dimensions.
