Which game would be most desirable and a mint HS-1/2/5 clone cabinet?
Yours was likely made by Star mfg.
The ones by Star and Board Market are almost identical in every single way except the board Market dynamo speaker cutout is different. Build quality, the control panel key notch, base assembly etc are all exactly identical. This is why i believe these cabs were likely commissioned by AmeriCorp to their specific specs.
wrong size I think.
duffcon says HS5 is 25 1/4 and mine is 23 3/4
I corrected my original post. HS-5 is 25 3/4" as measured on my cab. The 19" monitor and 23 1/4" panel makes this more of a hs-1 clone.
If your monitor is 19" and the control panel is anything less than 24" you almost 100% have a Dynamo HS-1/2 cab or replica.
The control panels for HS-1, HS-2, and HS-5 are getting a lot harder to find these days.
But they are for sure out there.
Yeah. the vertical one looks exact down to the chrome t molding and CP hole layout.
Mystery pretty much solved. Thanks.
Honestly, the best game to put in that cabinet is one you would enjoy.
i'll probably cut out and weld in a new blank panel or have a friend plasma cut me a section with SF layout and weld that in as I don't think I'll recoup much on this panel if I bought a new SF2 one
Wonder what it'd cost (or possibility) of doing a Raiden I, II, DX cabinet with a switcher
I would guess any cut corner panel that's 23 3/4" would fit that cab.
On mine I cut the pull out board in half and stuffed a bunch of pcb's in there and some switchers. I have 10 different control panels that I swap out plus I put in a lazy susan so I can rotate the monitor easily. These style cabs really do kick ass.
