Where's the Neo-Geo Multicart compatibility thread?
keithsarcade
St Peters, Missouri
I seem to recall a thread on this but I can't find it. I'm trying to move the 108-1 from my 1-slot to a 2-slot, can't get it to work.
Reset the memory in the neo geo's test menu and see if that helps.
The only real computability issues I seem to remember are the boards that use a daughter board. Those should only be used in the one slot. For the other carts it is best to just use that single cart in the system and if you have problems check the 5v line as I read of a lot of issues with low volage and the carts.
With my 161 in 1 cart on my 2 slot the two things I needed to do were remove the memory card from the system as do the reset in the test menu's.
