Where to start..
While my cabling could be look over after I took delivery wondering where else to start on the second monitor troubleshooting…
do you have a TPG? or another game to swap that monitor into? beyond that it sounds like you have a sick K7000. have you fixed monitors?
yes and yes, yeah just got lazy as when I was leaving I turned it all on and then one monitor was as such. Looked like vertical collapse at one point but then more on the screen..
also the other one is way out of focus so i have some flyback adjustments, xmen 6 player is somewhat overly complicated with all the x2 wiring setups for the CRTs
Yay fixed! Bad crt cable…now to work on the focus on one of the flybacks while 4 feet behind the front of the cabinet
Any mirror that gives you the ability to see the screen from while behind the cabinet will work. You can even prop one on a chair. It's just to see the changes to the screen while you adjust it.
