Where to get heat sink and eprom
needhelp
Donor 3 years: 2016, 2021, 2024
Indianapolis, Indiana
I was wanting to know if anybody knows where to get the heat sink and ROM that goes on the dual monitor play-choice board. I found out the other night that the ROM is bad and don't know where to get it at. Or if anybody know where I can find the file and where to buy the ROM to burn it onto a ROM.
thanks in advance
You should be able to get the file from MAME. MAME is a wonderful resource for fixing arcade boards - simply download the MAME ROMset, decompress, and you've got all the files for all the chips on the board.
It's probably in the PlayChoice BIOS ROM that's available for MAME. Then, just burn it to a blank ROM of the proper size (or reprogram the EPROM you've already got, if it's just corrupt, the chip might be OK).
As for the heat sink, any small glue-on heat sink should be fine.
-Ian
