Where to Buy Crimp StyleEdge Connectors??
teetdogs
Brighton, Colorado
I am trying to track down a good source for a 15/30 and 22/44 crimp style edge connector with the pins. All I can seem to track down is the stupid solder eyelet type.
Anyone know a good source for these?
I bought a set of these, which are sold by many vendors on ebay for $8-10.
http://www.ebay.com/itm/291504083166
The set is nice because it comes with a Molex pin tool for cables as well.
I did end up needing to file down the connector pin tool to make it a bit thinner, which made it work better.
The metal for the connector tools is a little soft, and it bends easily, but I suppose thayt's better than snapping. But for ten bucks you can't go wrong, and they work fine if you're careful with them.
without waiting for a new tool to ship...
...you use one leg of a discarded HOT. Bent out of the way, until it breaks, then you have two more tools to use. You can de-pin an entire jamma edge with one.
Can't remember who on KLOV posted that tip, but it works wonders.
